Which Thermodynamic Model In Aspen To Be Used For Ammonia Absorption I
#1 Nikhil Shipure
Nikhil Shipure
Posted 11 September 2019 - 10:55 PM
Dear Friends,
Please help me out with which Thermodynamic model to be used for Aspen Simulation for Ammonia absorption or scrubbing with water.
Thank you
#2 PaoloPemi
PaoloPemi
  • 550 posts
Posted 12 September 2019 - 12:36 AM
please , only one post :-)
About your question, in separations you need to solve mass + heat balance, which means fugacity (phase equilibria) and enthalpy (heat balance), at Cheresources you may find several threads discussing these topics,
as general rule, you may select some extended EOS (I have not access to Aspen but, as example, the Peng Robinson Extended with Huron Vidal mixing rules, available in Prode Properties gives low errors -compared to standard version- for liquid properties as heat capacity and it is very accurate for phase equilibria) , or you can select CPA based models (can be more accurate for association mixtures), for enthalpy you can also select BWR based models etc.
#3 breizh
  • 6,907 posts
Posted 14 September 2019 - 01:55 AM
You did not supply much info about your process,
If the solution is very diluted , you might consider Henry 's law ?
Edited by breizh, 14 September 2019 - 01:56 AM.
#4 Tanhieungo
Tanhieungo
  • 13 posts
Posted 08 December 2019 - 05:15 AM
i used elecnrtl and henrry option
#5 yulian99
yulian99
Posted 18 January 2022 - 11:56 AM
After reviewing several articles, generally as mentioned above, models such as peng-robinson and SRK are used
