Acid Gas - Caustic Wash - Hysys Help
h2s scrubber acid gas cleaning
#1 Max Domingues
Max Domingues
  • 38 posts
Posted 18 September 2019 - 02:33 PM
Hello to all!
Does anybody here could explain me how is the convergence behavior of Hysys on Acid Gas - Caustic Wash package?
I am simulating a scrubber to remove H2S and i don't understand the low efficiencies generated by Hysys and, eventually, when i change something - like change the package and then return to the old package - (not on the stream inlet), push run again, the results changes.
I know its an 'efficiency' matter but i don't understand what is happening.
I know if i change efficiencies manually, i can get any number i want but, at what cost? what is involved? See picture attached.
Thank you a lot!
Max
#2 sgkim
sgkim
  • 289 posts
Posted 22 October 2019 - 02:00 AM
Should'nt the column be reactive one?
#3 Max Domingues
Max Domingues
  • 38 posts
Posted 28 October 2019 - 05:49 AM
Dear sgkim, thank you for your attention to this topic.
Unfortunately, i really dont know about about reactive columns on absorpion process in Hysys. :blink:
This the reason of my post (to understand and learn more).
Could you explain me a little about this?
Thank you again.
#4 Nikolay_
Nikolay_
  • 169 posts
Posted 30 October 2019 - 03:24 AM
What version of HYSYS do you use? The Acid Gas - Caustic Wash package was released with V11. I didn't find Efficiencies folder in Hysys example file.
#5 Max Domingues
Max Domingues
  • 38 posts
Posted 04 November 2019 - 11:06 AM
Hi Nikolai! You are right! I am using Hysys V11.
The print screen attached is exactly the example that im working right now.
There  i can change the efficiencies but i was wondering about my modifications, if they are realistic or not.
#6 Nikolay_
Nikolay_
  • 169 posts
Posted 04 November 2019 - 09:08 PM
Hi Max,
When you deal with Efficiencies nobody help you. Intensive research and experimental data are needed. Aspentech isn't responsible. They are just programmers, you are just buyer.
#7 Tanhieungo
Tanhieungo
  • 13 posts
Posted 08 December 2019 - 05:19 AM
use rate base option to better
