Dear All
Good Day
We have a refinery fuel gas system in which natural gas is used as make up to maintained pressure. Natural gas is supplied from state own company and most of the time its supply pressure itself found less than the refinery fuel gas system. Hence refinery fuel gas system start to decrease and hurt the operation of furnaces specially steam methane reformer. We are evaluating to supply natural gas from discharge of natural gas compressor to refinery fuel gas system. The discharge of compressor is at 32 bar and 135 'C. Refinery fuel gas system is at 4.0 bar and 65 'C. We can install a line from discharge of compressor to fuel gas system and pressure control valve to maintain its pressure. But we found temperature after throttling is very high that is 128 'C. kindly suggest can we used this scheme or not. Is there any draw back of using hot fuel gas in burners. What other parameters we need to consider for this plant change.
Natural gas compressor is three stage piston compressor. 1st stage discharge after cooler is at 4.3 bar and at 60'C. These process conditions are more favorable than the last stage discharge of compressor. I have attached the diagram of actual and proposed plan for this modification. Please give your expert opinion weather we take off-shoot from compressor interstate stream for some other purpose or not.
Best Regards
Muhammad Farhan
305 FG.pdf 33.41KB
15 downloads
