Reflux Ratio
distillation reflux ratio
#1 Noay
Noay
  • 8 posts
Posted 19 November 2019 - 12:42 PM
I have calculated the minimun reflux ratio to be 0.42. Taking 1.5*0.42=1.08, Is reflux ratio of 1.08 too small for distillation? In this case, Ethyl acetate is being removed from Ethyl acetate-ethanol mixture.
Edited by Nafii, 19 November 2019 - 12:46 PM.
  • 7,062 posts
Posted 20 November 2019 - 01:54 AM
Thanks to share your work if you want to get a meaningful answer .
Note : The mixture forms an azeotrope !
http://www.separatio...om/Mainmenu.htm
You will find a link to support your calculation
https://checalc.com/distillation.html
a textbook for the basics on separation
https://escholarship...96n0xv#page-489
Good luck and enjoy the reading .
Edited by breizh, 20 November 2019 - 04:08 AM.
#3 Pilesar
  • 1,696 posts
Posted 20 November 2019 - 09:41 AM
Check your math using a calculator, also.
