K Factor Api 12J Vs Gpsa And De Rating For Pressure
separator sizing api 12j gpsa k factor derating pressure
#1 james.corrobro@gmail.com
  • 48 posts
Posted 19 November 2019 - 01:37 PM
API 12J calls for using k factor as 0.12 to 0.24 for vessels with length as 5 feet.
GPSA calls for de-rating of thek factor based on pressure.
Pressure, psig De-rating For Mesh Demisters At
Elevated Pressure
Atmospheric 1.00
150 0.90
300 0.85
600 0.80
1,150 0.75
If I am using API 12J for k factor do I need to de-rate the k factor? For e.g. if my vessel height is 5 feet and is operating at 1150 psig. Do I just use a k factor between 0.12 and 0.24? or do I use 0.24 and de-rate it as per GPSA?
If I am using GPSA for sizing do i use 0.35 as the max k value provided by GPSA and use 0.75 as de-rating factor??
#2 Bobby Strain
Posted 19 November 2019 - 04:32 PM
So, what service is the vessel for? Are you sizing a real vessel?  If it's for real, you need to talk to the demister vendor.
Edited by Bobby Strain, 20 November 2019 - 01:10 PM.
#3 james.corrobro@gmail.com
  • 48 posts
Posted 19 November 2019 - 07:31 PM
Vessel is a discharge scrubber in natural gas service.
How is 12J only for horizontal sep. ..it provides guidelines for vertical sep.
#4 breizh
  • 7,028 posts
Posted 19 November 2019 - 11:32 PM
A few resources to support your work.
