Series And Parallel Configuration Of Shell
#1 274@P6
274@P6
  • 43 posts
Posted 22 January 2020 - 06:52 AM
Hi to all,
Can anyone explains about the configuration of "Shell connected in series and parallel" which mentioned in TEMA Sheet?
If possible, share TEMA sheet explanation guide for each term.
Edited by 274@P6, 22 January 2020 - 06:53 AM.
  • 1,635 posts
Posted 22 January 2020 - 09:01 AM   Best Answer
Sometimes a heat transfer service requires more than one physical exchanger. If the multiple exchangers are identical, then a single data sheet can be used to describe them. Series and parallel describe how multiple exchangers are connected. If you have just one exchanger described in the data sheet, you ignore this part of the TEMA data sheet.
