In CDU/VDU unit Desalter is provided downstream of crude charge pump. What should be the design pressure of this vessel?
Is it should be crude charge pump-shutoff pressure
or
it should be maximum operating pressure of vessel + 2 kg/cm2g similar to design pressure of other pressure vessel.
It may be noted that this vessel is protected with PSV.
The conservative approach is to design this vessel for pump shut-off however this will lead downstream piping and equipment to be in higher class which has cost impact.
Please suggest what is the practical approach and why?
Many Thanks
