Knock-Out Drum Inlet Detail
#1 ryn376
ryn376
  • 97 posts
Posted 07 February 2020 - 10:52 AM
Does anybody have a knock out drum inlet detail and micron size limitation? I have a two phase stream of nitrogen, ethanol, methanol and water going to atmosphere where almost all the condensed EtOH, MeOH, and water should be knocked out for environmental permitting reasons. I was planning on using a gravity KO pot with demister pad.
Inlet flow ~420 scfm, 91 F, 15 psia
Liquid phase: 6.5 kg/hr MeOH, 104 kg/hr EtOH, 9 kg/hr water
vapor phase: 4.1 kg/hr MeOH, 36 kg/hr EtOH, 2 kg/hr water
Thank you.
Edited by ryn376, 10 February 2020 - 09:00 AM.
  • 6,928 posts
Posted 09 February 2020 - 11:53 PM
1)Consider the literature posted in another post about separator a few days ago  :
Separator Parts Internals Design
To add to it let you consider also the document attached about KO drum internal .
2)Is this the right technology to get rid of organics ?
 Wet Scrubber, Adsorption Tower with activated carbon or Thermal oxidizer more suitable !
https://heilprocesse...n/voc-scrubbers
3)Did you check with the authorities ?
My view
Edited by breizh, 11 February 2020 - 08:08 PM.
#3 ryn376
ryn376
  • 97 posts
Posted 10 February 2020 - 11:18 AM
Breizh,
Thank you for your response. The client actually has a relatively large allowable VOC permit and since the only VOC's in this process are as stated, we do not have to get to extremely low VOC concentrations. Thanks for the thought regarding scrubbers, etc. though. They mainly do not want to exceed the permit and have elected to use a HX to condense the stream.
Namely do you have an inlet detail? Based on the one article from the other post. A half pipe seems easiest/more economical, but no details were shown.
Edited by ryn376, 10 February 2020 - 02:20 PM.
#4 breizh
  • 6,928 posts
Posted 10 February 2020 - 06:50 PM
I have attached a scan of a document ( french literature)  where you can find some information about the inlet pipe (tubulure entree separateur vertical) :
orientation :45 degrees
location of the wear plate to mitigate erosion effect (liquid droplets)
maximum height of the liquid
You can review this guide also:
https://www.red-bag....sel-sizing.html
No more to offer , let you try GPSA handbook , Perry's handbook....
Edited by breizh, 10 February 2020 - 07:06 PM.
#5 breizh
  • 6,928 posts
Posted 13 February 2020 - 02:58 AM
For safety concern don't release organics (flammable) to atmosphere ,Check for LEL . Make sure you have all preventions means to prevent fire , explosion .... For example pay attention to lightning .
My view
Edited by breizh, 13 February 2020 - 02:59 AM.
