Please provide the following information so that the group members will be able to help you
1) Fluid Handled
2) Pressure & Temperature of the system
3) % of toxic components present in the stream
Prima facie I think this isolation arrangement is provide as the system is high pressure
Hello Sir. Thank you for replying.
1) Fluid Handled: Hydrocarbon (Waxy Lubricant)
2) P: 169 kg/cm2g T: 320°C
3) Hazard: Non-toxic but flammable
Is draining of pressure instruments a problem in such cases? Why is that so? Because the P&ID instructs to locate the instruments at top of reactor with self draining leads and to use pipe instead of tubing.
Thank you for your valuable time.
