Hello.
I need to find the mass flow rate of superheated steam entering the turbine and the mass flow rate of bled vapor. can anyone please help with this? Any more information required, let me know. Thank you.
Posted 17 March 2020 - 02:43 AM
Hello.
Posted 17 March 2020 - 03:07 AM
https://www4.eere.en...ol/equipTurbine
You may use the tool above .
Examples built in are available to support your query .
notes : Should be mass +energy balances , right?
Something is weird with your data (stream 3) , from my table (Spirax Sarco)
the minimum pressure is 0.125 bar which corresponds to 50.25 C .May be the reason for your query?
my calculation (kg/s)
m1= 23.7821 m3 =19.8 m2=3.9821
Edited by breizh, 18 March 2020 - 07:16 AM.
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
