After reading this CSB document on the Kuraray incident (https://www.csb.gov/...eng06.pdf?16387), we identified several relief systems with similar designs - horizontal discharge of flammable vapor rather than vertical. Does anyone know what the basis or reason is for discharging flammable vapor horizontally rather than vertically. API 521 appears to be based on vertical discharge. Why would engineering firms design and install these systems with horizontal discharge?
csb_kuraray_factual_eng06.pdf 810.7KB
4 downloads
Horizontal Discharge Of Flammable Vapor
Started by dozerboy, Mar 24 2020 10:44 PM
No replies to this topic
Posted 24 March 2020 - 10:44 PM
Horizontal Decanter Sizing CalculationStarted by Guest_peejoee_* , 07 Oct 2025 |
Negative Pressure Discharge / Negative At High PointStarted by Guest_felderosfelder101021_* , 05 Jul 2025 |
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
