Crude Oil Production Well Data Input In Aspen Hysys
Posted 01 April 2020 - 04:30 PM
i do have crude oil data that i didn’t know how to input them in aspen hysys..
The data consists of different wells properties and compositions
light HCs
C7+ which i added as hypo with the available data which gives density and MW and estimated other properties
but i could understand how to input bubble point temp and pressure, GOR, and API of residual
so can anyone help explaining the methodology
thanks
regards
Posted 13 May 2021 - 04:44 AM
Hi iOM,
No need to enter GOR & API.
Composition, Is it reported in STD condition or reservoir condition or any other Separator condition.
Enter Composition values in HYSYS as per reported conditions (Pressure & Temperature)
To get the required GOR, you have to adjust it manually input Produced gas.
Let me know ,if you need anything.
Posted 13 May 2021 - 03:07 PM
For GOR you have to simulate a dummy separator and then adjust gas flow (as required)
API will be as per composition and will be calculated automatically by HYSYS
since you different wells, need to know what proportion each well is contributing to total flow
pressure & temp. conditions need to be input as per available data
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , 23 Mar 2026 |
Crude Assay Pure Component AdditionStarted by Guest_darknight1991_* , 17 Jan 2026 |
