How Can I Simulate Steam Generation From The Heat Released In A Reacto
Posted 10 April 2020 - 06:26 AM
Posted 13 April 2020 - 05:20 AM
It is not clear what kind of process you are talking about.
You do not mention anything specific for your process.
In general: the operating temperature of a reactor is chosen on basis of kinetics, required conversion, optimal usage of reaction heat, et cetera. It is not just an arbitrary choice between either 35 or 623 degrees.
Obviously the lower the reactor temperature the bigger the reactor has to be, and more catalyst is required (if applicable).
However the higher the reactor temperature of an exothermic reaction the lower the equilibrium conversion, and the more expensive the metallurgy.
To remove the heat of reaction you could have multiple reactors in series with steam generators in between them to lower the process stream temperature to the next reactor.
Or you could have a reactor with steam generation piping inside it.
Posted 13 April 2020 - 12:16 PM
I am designing a hybrid photo/thermochemical process to produce 1 kmol/s Hydrogen to shed light on the viability of the Cu2O/CuO subcycle using ASPEN PLUS?
These are the reactions for the complete cycle
H2O + 2 NH3 + SO2 --> (NH4)2SO3 (25 degrees celsius, chemical absorption)
(NH4)2SO3 + H2O--> (NH4)2SO4 + H2 (65 degrees celsius, solar photocatalytic step)
(NH4)2SO4 --> H2SO4 + 2 NH3 (250 degrees celsius, thermocatalysis)
H2SO4 --> SO3 + H2O (400 degrees celsius, thermocatalysis)
SO3 + Cu2O --> 2 CUO + SO2 (650 degrees celsius, thermocatalysis)
2 CUO --> Cu2O + 1/2 O2 (1050 degrees celsius, thermocatalysis)
My Problem
I want to circulate 15 kmol/sec to ensure liquid operation and that no precipitation of the ammonium sulfate and sulfite takes place. In the Low temperature reactor ammonium sulfate decomposition takes place. I have added a component separator to separate the gaseous mixture SO2, NH3 from the aqueous solution H2SO4. H2O serves no purpose and is considered a drawback because more heat duty is required to heat the feed streams (H2O+H2SO4 and SO3+H2O) to the respective temperatures (400 C and 650 C) and I cannot strip H2O from H2SO4. In the last reaction, I recycle Cu2O to the reactor with SO3+H2O. I used the exiting gaseous mixture (SO2+H2O) to exchange heat to minimize utility and heat the H2SO4+H2O to the reactor and (SO3+H2O) and recycled to the absorber. The (SO2+NH3) at 250 C cannot raise any of the cold streams that require heating to above 10 degrees celsius because of tits small flow rate . The reaction in the absorber takes place at 25, however the feed streams are at much higher temperatures as I mentioned is much higher so I want to utilize the significant amount of heat wasted to produce steam to heat the cold streams.
Posted 13 April 2020 - 01:05 PM
Please make a simplified flow diagram to indicate how the different reaction steps are connected, what inlet temperature is required for each reactor, what maximum outlet temperature is allowed for each reactor, et cetera. Include also recycle streams in the diagram.
Posted 13 April 2020 - 02:30 PM
Absorber
Inlet Streams:
SO2+NH3 from sep-01 at temperature 250
SO2+H2O exiting sep-02 at temperature 650
Outlet Streams
(NH4)2SO4 + H2O at temperature 25
Photoreactor
Inlet streams
(NH4)2SO3 + H2O at temperature 25 from Absorber
Outlet streams
(NH4)2SO4+H2+H2O + (unconverted NH4)2SO3) temperature 65
LTR
(NH4)2SO3-->SO2+2NH3+H2O (250 degrees celsius, thermocatalysis)
Inlet stream
(NH4)2SO4+H2O at temperature 65 from Photoreactor
Outlet stream
H2SO4+H2O+SO2+NH3 at temperature 250
MTR
Inlet Stream
H2SO4+H2O at temperature 250 from sep-01
Outlet Stream
SO3+H2O at temperature 400
GTR
Inlet stream
Cu2O at temperature 1050 from sep-03
SO3+H2O at temperature 400 from MTR
Outlet stream
CuO+ SO2 at temperature 650
HTR
Inlet stream
CuO at temperature 650 from sep-02
Outlet stream
Cu2O+O2 at temperature 1050
Edited by Elmansi, 13 April 2020 - 02:31 PM.
Posted 15 April 2020 - 05:32 AM
In the mean time I noticed that you had already opened another topic on this subject in which you stated:
My Problem
I want to circulate 15 kmol/sec to ensure liquid operation and that no precipitation of the ammonium sulfate and sulfite takes place. Unfortunately, I think because of this, high heat duty is required in the Low temperature reactor where ammonium sulfate decomposition takes place. I have added a component separator to separate the gaseous mixture SO2, NH3 from the aqeous solution H2O. From this point in the process, H2O serves no purpose and is considered a drawback because more heat duty is required. How can we go about this problem of seperating H2SO4 from water without the addition of new chemicals.Cu2O exiting the reactor operating at 1050 is added directly to heat the SO3-H2O feed to the reactor (650), the gaseous mixture from this reactor is used to heat H2SO4 + SO3 + some of the ammonium sulfate, and finally returned to the absorber, significant heat is wasted. As a result, the calculated efficiency is not satisfying, 13 %. Also in one of the heat exchangers I am not sure whether at the specified outlet temperature the SO2-H2O will undergo phase change , so how can I account for the phase change if any in the specification of the MHeatx should I include in the phases vapor-liquid?
How can I input manually the heat capacities for the components of my system and allow aspen to heat based on these heat capacities.
https://www.cheresou...n-plant-design/
I never use Aspen Plus so I can not help you with the specific input options of that particular simulator.
Whether there is a phase change in a reactor or heat exchanger will be determined by the simulator based on your inputs.
From the above simulation scheme I get the impression that you use simple component separators for H2-sep, Sep-01 , Sep-02 and Sep-03 , however in the real world you have to take into account vapor/liquid equilibria and use Flash Separators in combination with a suitable Property Method.
For the absorber you also have to obey the laws of physics and thermodynamics. You can't add multiple streams and assume that all components end up in only one liquid outlet stream, unless maybe if you use sufficiently high absorber pressure. Or if it is not really an absorber but a mixer with possibly a mixed phase outlet stream.
Also for the reactors you have to use suitable property methods and thermodynamics.
It is not clear what is the phase of CuO and Cu2O containing streams. Are they slurry, or what?
Did you actually run this simulation, and if so, did you get a converged solution?
If so, indicate which reaction is endothermic and which is exothermic,
and what is the pressure, flowrate, composition and phase of each stream.
Edited by PingPong, 15 April 2020 - 05:33 AM.
Posted 15 April 2020 - 11:45 AM
My Problem
Posted 18 April 2020 - 03:43 AM
I am not permitted to upload apw or tmp files.
My Problem
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
