Reliable Power Supply
#1 Beergson
Beergson
  • 50 posts
Posted 28 May 2020 - 11:32 AM
Dear Sirs,
Are there available any sources which give any recommendations when plant power supply can be considered as an reliable.
For example: we have two Main Supply Points, each is supplied from: a) Local Power Plant B) external power supplier . Each refinery plant is supplied from two Local Supply Points which are fed from both Main Supply Points.
For a few most critical plants we have also third power supply from third, another, Local Supply Point, but still fed from two Main Supply Points , mentioned before.
Is this third power supply can be considered as an reliable?
Any help will be appreciated.
Best regards.
#2 Zauberberg
Zauberberg
  • 2,728 posts
Posted 31 May 2020 - 08:14 AM   Best Answer
Probably the best resource on the above subject is IEEE Gold Book, i.e. IEEE Standard 493 "Recommended Practice for the Design of Reliable Industrial and Commercial Power Systems".
Performing RAM study for different alternatives should help you make the right decision.
#3 Beergson
Beergson
  • 50 posts
Posted 05 June 2020 - 04:02 AM
Thanks Zauberberg!
Kind regards
#4 Zauberberg
Zauberberg
  • 2,728 posts
Posted 07 June 2020 - 03:24 AM
All 17 Annexes of IEEE 493-2007 can be downloaded from IEEE web site: https://standards.ie...7_downloads.zip
If the link above does not work, go to: https://standards.ie...d/493-2007.htmland scroll down to use the link under "Additional Resources Details".
