I am trying to simulate an organic Rankine cycle. What is the minimum temp difference between cold air and working fluid in? Also, is it possible for the minimum temperature difference to be at the beginning of the heat transfer? Or should it be like the line drawn in pencil?
Organic Rankine Cycle Simulation/min. Temperate Difference
Started by Noran Shedid, Jul 07 2020 06:18 AM
heat transfer
Dwc SimulationStarted by Guest_Yasmine_* , 11 Nov 2026 |
Recommended Sources For Biochemical And Organic Chemical PropertiesStarted by Guest_dpunnn_* , 09 Oct 2026 |
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Simulation Of Natural Gas Water Dew PointStarted by Guest_guoyinyanliner_* , 03 Nov 2025 |
