I am trying to simulate an organic Rankine cycle. What is the minimum temp difference between cold air and working fluid in? Also, is it possible for the minimum temperature difference to be at the beginning of the heat transfer? Or should it be like the line drawn in pencil?
Organic Rankine Cycle Simulation/min. Temperate Difference
Started by Noran Shedid, Jul 07 2020 06:18 AM
heat transfer
![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
Aspen Hysys Simulation Of Acid Gas Removal UnitStarted by Guest_R.t_* , 22 May 2025 |
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
![]() Dynamic Simulation After Feed Flow ReductionStarted by Guest_Kakashi-01_* , 20 Mar 2025 |
Converting A Static Simulation To Dynamic SimulationStarted by Guest_tomr91_* , 26 Feb 2025 |
