Risk Of Blocking For Two Positions Three Way Valve.
#1 Jalalirad
Jalalirad
  • 3 posts
Posted 08 July 2020 - 04:09 AM
relief valve or pressure relief valve (PRV) is a type of safety valve used to control or limit the ... The blowdown can vary from roughly 2–20%, and some valves have ... In high-pressure gas systems, it is recommended that the outlet of the relief ..
Edited by Jalalirad, 13 August 2020 - 02:54 AM.
#2 fallah
  • 5,026 posts
Posted 08 July 2020 - 06:43 AM
Please upload a simple sketch of the system you described...
#3 Bobby Strain
Posted 08 July 2020 - 09:05 AM
And what fluid is handled.
#4 Chemitofreak
Chemitofreak
  • 292 posts
Posted 12 July 2020 - 01:51 AM
What is the type of pump in your service, I guess it will be a positive displacement pump.
The relief valve protecting the discharge piping should be as close as possible to the pump and there should not be any valve in between.
If the fluid is fouling, I would consider the possibility of a blocked outlet, but based on your diagram the relief valve would be of no use in this scenario, because the 3-way valve is at the the upstream of the relief valve, in case the 3 way valve blockage is considered then the piping between the pump and the 3-way valve will overpressurise during a blocked outlet scenario.
