Hello all,
Edited by SGAJSE, 19 July 2020 - 02:15 AM.
Posted 19 July 2020 - 01:54 AM
Hello all,
Posted 19 July 2020 - 02:16 AM
I guess the problem in your case is that the suction piping is gaining heat from the ambiance (especially in summers). Try insulation the line, that might help you
Posted 19 July 2020 - 02:26 AM
You should consult the vendor : https://www.nikkiso....submerged.html
Consider the following link with similar issue : https://www.eng-tips....cfm?qid=284608
my view
Edited by breizh, 19 July 2020 - 03:09 AM.
Posted 20 July 2020 - 01:45 AM
Hi Chemitofreak
Thank you for your response.
the suction line is very long and complex but we rather believe that the problem is related with other thing, because the suction line is shared with another pump (loading pump).
we don't experience any cavitation problems with the ethylene loading pumps which are located in the same area, having the same NPSHr, operate with similar conditions and have equally complex and very long piping section. the loading pump can operate with a tank level as low as 1 m.
Posted 20 July 2020 - 05:03 AM
Hi Chemitofreak
Long and complex suction line for a boiling liquid is not a good idea.
Although the NPSHr for both the pumps is the same is the NPSHa for both the pumps same ?
I guess you are using the canned pumps, compare how deep both the pumps are located below the ground.
Posted 20 July 2020 - 05:28 AM
Hi Chemitofreak
"Long and complex suction line for a boiling liquid is not a good idea." That was the design of the ethylene plant by Stone & Webster since 1986.
the net positive suction head available for both pumps are nearly the same, the difference only in the pump capacity (different velocity).
yes, the pumps type is vertical multistage pot mounted submerged motor pump.
Posted 20 July 2020 - 06:23 AM
Hi Chemitofreak
Pump capacity will have an impact on NPSHA as more flow will lead to more frictional loss (assuming the pipe diameter is the same in both the cases)
Is your issue based on the ambient weather conditions ? I mean summer and winter
Edited by Chemitofreak, 20 July 2020 - 06:25 AM.
Posted 20 July 2020 - 04:40 PM
Insufficient NPSHa doesn't usually overload a pump motor. I would usually look for pumping a greater volume which requires more power. But, then, you didn't tell us very much that is helpful. You also didn't attribute the trip to motor overload. So, we need a lot more information if you want help.
Edited by Bobby Strain, 20 July 2020 - 04:43 PM.
Ethylene Plant - Is The Dilution Steam Generation System An "unfirStarted by Guest_Alfreedo_* , Yesterday, 02:31 PM |
Ethylene Oxide Off-SpecStarted by Guest_Movers_* , 25 Feb 2026 |
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
Lng ProblemStarted by Guest_guoyinyanliner_* , 10 Dec 2025 |
