How To Determine The Relief Rate Of Hx Tube Rupture Scenario
#1 phoenixmoca
phoenixmoca
  • 20 posts
Posted 06 August 2020 - 01:26 AM
Hi, everyone.
When the relieving fluid is liquid is it necessary to choose the smaller one from the calculated relief rate and the normal flowrate?
Thank you in advance.
#2 fallah
  • 5,026 posts
Posted 06 August 2020 - 01:33 AM
Hi, everyone.
Your query isn't so clear...please explain clearly about the conditions of low and high pressure sides and the calculation you did perform to specify the relief load...
#3 phoenixmoca
phoenixmoca
  • 20 posts
Posted 06 August 2020 - 02:02 AM
Hi, fallah,
This is a general question about the tube rupture scenario for the liquid relief.
For tube rupture scenario the fluid in high pressure side is still liquid instead of flashing. So the relief rate calculation is conducted and much higher than the normal liquid flowrate in high pressure side. My question is whether to choose the smaller data(the normal liquid flowrate) as the relief rate to size the PSV.
#4 breizh
  • 6,925 posts
Posted 06 August 2020 - 02:15 AM
To support your work , consider the documents attached.
Hope this is helping you.
#5 fallah
  • 5,026 posts
Posted 06 August 2020 - 04:13 AM
Hi, fallah,
General question will lead to general answer...
The calculated relief load is to be considered in relevant PSV sizing even if it's higher than normal flow rate...
