Compressor Testing
Posted 18 August 2020 - 05:24 AM
For compressor fouling, I want to compare some previous point in time possibly startup clean conditions at the operating inlet conditions that day to some later point in time today say at today operating inlet conditions therefore we have to convert today values to the same inlet conditions as previous! The difference would represent the amount of efficiency loss due to fouling thus normalising for change in operating conditions.
Request your help in how generally we do this conversion of compressor performance for change in inlet conditions here
Posted 18 August 2020 - 08:02 AM
If I was in your shoes , I will compute and compare the today data to the data at the start up ( brand new and clean unit) .
For a given condition ( Pressure outlet , Flow rate) today and at start up I will calculate/measure the energy consumption (driver) per m3 of compressed gas .
With these 2 data I will be able to evaluate the impact on the compressor performance .
my 2 cents
Edited by breizh, 18 August 2020 - 08:03 AM.
Posted 18 August 2020 - 10:28 AM
Or any other way
Posted 19 August 2020 - 10:38 AM
Chetan Chavan
Posted 19 August 2020 - 11:03 AM
What is the method generally used to achieve this
Posted 20 August 2020 - 03:49 AM
I want your help on how to normalize efficiency values when compressor inlet conditions changes
Posted 21 August 2020 - 03:39 AM
Consider these resources to support your work.
Good luck.
Edited by breizh, 21 August 2020 - 04:11 AM.
Posted 30 August 2020 - 06:04 AM
I m looking for Evaluation of Polytropic efficiency for two points like one is for SOR conditions when we have started new cleaned compressor and after say three months , my inlet conditions changes also so how to account for change in inlet conditions and it's impact on polytopic efficiency here
#10
Posted 18 September 2020 - 09:48 PM
Still I could not find any solution for my issue of normalisation of compressor efficiency
#11
Posted 18 September 2020 - 09:53 PM
Still I could not find any solution for my issue of normalisation of compressor efficiency. Plz help me in this. I have two points for compressor efficiency one is at SOR start of Run and second is today. SOR will be rather clean compressor and today is copied compressor
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
