At what pressure we should design finger type valve unloader i.e at suction pressure or at discharge pressure?
If we design it at suction pressure then if our compressor is shut off suddenly at higher pressure in cylinder then how to unload it?
Please help
Unloader Pressure
Started by Pratapsinh, Aug 28 2020 09:59 AM
Posted 28 August 2020 - 09:59 AM
Posted 30 August 2020 - 05:50 AM
Hope this is for reciprocating compressor and service like nitrogen compressor or instrument air compressor here.
Posted 30 August 2020 - 05:55 AM
This valve is called blowoff valve or unloader valve .when compressor stops this valve opens and release the pressure and finally suction and discharge pressure is same when compressor unloads
Posted 30 August 2020 - 05:56 AM
It should be designed at discharges pressies only
Posted 13 September 2020 - 02:00 PM
Posted 13 September 2020 - 02:04 PM
Thanks for your reply
Yes I am talking about reciprocating compressor valve unloaders.
Whether we have to design this finger type unloaders at suction or discharge for capacity control?
Because at suction pressure also it will actuate as cylinders pressure drop to suction pressure during its suction stroke
Shell And Tube Pressure DropStarted by Guest_UofUChemE_* , 08 Jun 2018 |
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
