Desalter Mass Balance
#1 iOM
iOM
  • 8 posts
Posted 21 September 2020 - 05:05 PM
Greetings dears,
i have went through on below link and read all valuable replies there in addition to Oilfieled processing Vol. 2
https://www.cheresou...r-mass-balance/
However i still didn’t get why the salt content after dilution and mixing is the same as the content leaving the oil stream (Kb = Kc) while we still do have the salt in the reject brine?
overall MB, B = C + V
Salt MB, B Kb = C Kc + V Kv
I know that we are diluting with fresh water increasing water droplets population within the stream thus with electrostatic grids aid to decrease the BS&W and salt content in the oil stream to the desired spec. and Z (lb salt/1000 bbl) = B (bbl brine / bbl crude) * Kb (lb salt/bbl brine)
I’m still confused with Kb = Kc.. I appreciate explaining this equality.
  • 6,940 posts
Posted 21 September 2020 - 08:34 PM
Consider the resource attached with examples, extract from Oilfield processing -volume 2 crude oil by Francis S  Manning and Richard E Thompson .
You should also consider your favorite search engine for more information.
Good luck.
#3 bikashmallick
bikashmallick
Posted 05 October 2021 - 04:43 AM
As pointed out by iOM, I could not make out why Kb = Kc and this is very much important to understand because all material balance equation for salt is based on this.
So It will be extremely helpful, if this equality is explained.
#4 breizh
  • 6,940 posts
Posted 07 October 2021 - 10:44 PM
hi,
The attachment with BM .
