Controlling Flow Of Peristaltic Pump
#1 kangas
kangas
  • 127 posts
Posted 28 September 2020 - 09:53 AM
I have a reciprocating pump that needs to pump a chemical at two different tanks at the same time but at different dosing rate. Is it possible to achieve this with a control valve? Is it vulnerable to damage in this configuration? What's the standard way?
#2 latexman
  • 1,893 posts
Posted 28 September 2020 - 10:17 AM
One way is to create a header using a PT and CV that spills back to the source tank.  Then, use the destination(s) weigh cells or a flow meter and a CV for each destination.
#3 Bobby Strain
Posted 28 September 2020 - 12:48 PM
Don't be cheap. Provide 2 dosing pumps. And a spare if necessary.
#4 breizh
  • 6,931 posts
Posted 28 September 2020 - 05:48 PM
You should consult representative of Pulsafeeder , Lewa or Milton Roy .
Load cells or weigh cells on each chemical tanks  associated with PLC to calculate the mass over time  are also an option .
Edited by breizh, 29 September 2020 - 12:14 AM.
