Lhv Of Fuel
fuel properties calculation
9 replies to this topic
#1 Danish John Paul
Danish John Paul
  • 15 posts
Posted 12 October 2020 - 11:08 PM
Please explain the steps on how to find the LHV using any software or hand calculation. Please share if any notes if you are having :-)
Is LHV same as the calorific value? Do we have anything to do with LHV and HHV and where doe we specifiy?
Why do we always care about the LHV of a fuel? Why not HHV?
Thank you in Advance
Danish
  • 6,940 posts
Posted 12 October 2020 - 11:21 PM
Consider the table attached with comments to support your query.
Yes heating values and calorific values are the same .
Sometimes you can read calorific power , all the same :
PCI =LHV;
PCS =HHV
Edited by breizh, 12 October 2020 - 11:45 PM.
#3 Danish John Paul
Danish John Paul
  • 15 posts
Posted 13 October 2020 - 01:52 AM
PCI =LHV;
PCS =HHV
Sir,
Can you please share how the LHV is significant for Flare system design?
#4 breizh
  • 6,940 posts
Posted 13 October 2020 - 02:29 AM
Review the standard attached , page 26.
Hope this is helping you
#5 fallah
  • 5,026 posts
Posted 13 October 2020 - 03:32 AM
Measuring the LHV of the flare gas mixture is required to determine the minimum quantity of assist gas.
#6 Danish John Paul
Danish John Paul
  • 15 posts
Posted 13 October 2020 - 07:31 AM
Does it has anything to do with the diameter of the flare tip and the ringlemann scale for the quality of smokeless flaring?
Why is that we never go for the HHV value of the fuel?? HHV value will always be higher than LHV. But we don't find its use anywhere..
Can you please enlighten on the term "flexibility normal flowrate". This has been asked by the vendor for a flare design.
How do we determine the design of flare for 0-100% flowrate?
Edited by Danish John Paul, 13 October 2020 - 07:32 AM.
#7 fallah
  • 5,026 posts
Posted 13 October 2020 - 09:08 AM
When LHV of flare gas is to be evaluated for estimation of required assist gas, there would be no need to evaluate the HHV...
Normal flow rate which has been asked by vendor might be the continuous relief load plus purge gas...
#8 breizh
  • 6,940 posts
Posted 13 October 2020 - 07:42 PM
A doc from John Zinc , the reference company on the subject : Selecting the proper flare system .
LHV vs HHV  , consider the link attached
https://www3.epa.gov...SD_04_19_07.pdf
Edited by breizh, 13 October 2020 - 08:07 PM.
#9 Napo
Napo
  • 350 posts
Posted 09 April 2021 - 09:55 AM
Dear Breizh,
The second attatchment is not possible download (productión-flares.pdf).
Napo.
#10 breizh
  • 6,940 posts
Posted 09 April 2021 - 06:25 PM
Attached document
