Limitation For The Velocity At The Outlet Of The Psv
#1 bp77
bp77
Posted 16 October 2020 - 01:32 PM
Do we have any limitation for the velocity at the outlet of the PSV, not at the tailpipe?
We have a PSV 4"X6".At the outlet of the PSV, we have to change the pipe size to 16" with two reducers.
The gas's velocity is 969 m/s at 6" outlet, but it will decrease for 16" tailpipe.
The mass flow is about 160000 kg/hr, and the reaction force is about 40 kN; it seems this force is too high for this PSV.
#2 latexman
  • 1,893 posts
Posted 16 October 2020 - 02:05 PM
Is it a 4P6?  If so, beware of extra high inlet and outlet pressure drops and:
Body Flow Limitations:
Reference: Guidelines For Pressure Relief and Effluent Handling Systems, Center For Chemical Process Safety
of the American Institute Of Chemical Engineers, 1998, pages 38-39.  "On certain occasions, the designer can encounter a dilemma when sizing a tail pipe to meet the built-up back pressure limitation for conventional pressure relief valves. Calculations for a tail pipe of the same size as the outlet flange can say that the built-up back pressure exceeds the allowable limit even if the length is reduced to zero."
The 4P6 simply has a flow nozzle (orifice) that is too big for the API 526 body.
Solutions may be:
  1. Raise or lower the set pressure (there is a lower practical limit and MAWP sets upper limit)
  2. Change body size keeping same orifice size (limited by availability)
  3. Use a smaller orifice in the same body (limited by availability)
  4. Use a restricted lift valve
  5. Use two or more smaller valves
  6. Use a balanced valve
Edited by latexman, 16 October 2020 - 02:12 PM.
#3 bp77
bp77
Posted 16 October 2020 - 02:56 PM
Thanks Latexman for your reply
yes this is 4P6
Edited by bp77, 16 October 2020 - 02:56 PM.
#4 breizh
  • 6,939 posts
Posted 16 October 2020 - 09:23 PM
To add , consider this extract of LESER'S  handbook , chap 6 part 6-4 .
Hope this is helping you
