what is the reason trays falls in distillation column in methanol plant
Posted 26 October 2020 - 03:46 PM
Posted 27 October 2020 - 07:15 AM
Posted 30 October 2020 - 01:48 AM
During turnaround of our methanol plant, we found 22 trays fallen and some of them bulged as well. corrosion is one of the problem but bulging the trays is not understandable, can any one explain what is the reason of trays fallen or bulging. our column have total 83 trays. plant is designed by UHDE in 1984.
Posted 30 October 2020 - 01:50 AM
we have sieve trays, your though make sence, trays was full of rust and pressure difference is one of the cause, can you please let me know the step (procedure) to calculate delta pressure, normal operating pressure is 1.2 barg and column have 83 trays. operating temperature 120 0C.
Column: Total trays 83
Tray 1-22: spacing 350 mm
Tray 23-39: spacing 520 mm
Tray 40-67: spacing 74 mm
Tray 68-83: spacing 11 mm
regards
Posted 30 October 2020 - 07:59 PM
Most commercial column simulators will predict pressure drop for sieve trays. You can get a free column hydraulic simulator from Koch or Sulzer. However in this instance simulators won't be that useful and you will need measured differential pressure. If you do not have pressure transmitters at the top and bottom of this column, that is something to install while you are down to fix the internals. If you got 35 years of life from these column internals, congratulations.
Posted 30 October 2020 - 09:32 PM
You may find pointers in the doc attached . Pilesar is right , 36 years is a lot for such equipment .
You may consider to perform a scan at the start of the column (rebuilt) to follow the degradation over the years .
Note : Consider to set a preventive maintenance program , with a check during turn around .
![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
![]() Distillation Column Top PressureStarted by Guest_halkeshhulk_* , 27 Jun 2025 |
![]() Distillation Column Top & Bottom TemperaturesStarted by Guest_halkeshhulk_* , 09 Jun 2025 |
![]() Distillation Tower Top And Bottom Temperature And PressureStarted by Guest_student55_* , 27 Mar 2016 |
Urea PlantStarted by Guest_MLGP_* , 20 Apr 2025 |
