Dear all,
Prv Inlet And Outlet Piping.
Posted 12 November 2020 - 12:24 PM
Posted 12 November 2020 - 03:33 PM
It can be flanged and/or welded. Just assign and follow the appropriate piping spec for each pipe.
Posted 12 November 2020 - 04:20 PM
Consider the recommendations from LESER in the doc attached to support your work .
Hope this is helping you
Posted 14 November 2020 - 12:41 AM
Thank you sir, but this doesn't specifically says about piping joints whether flanged/welded. However, its a good informative document. Thanks.
Posted 14 November 2020 - 01:14 AM
Dear all,
I have a query which i think is more related with piping.Is it allowed to have ALL PRV's inlet or outlet piping joints to have flanged connection.Or it should be only welded joints. Please refer the sketch.If it (welded joints) is mandatory requirement could you please provide any standard/code reference.Thanks in advance.Shantanu.
The joint you referred to doesn't need to be flanged; just if you want having pipe spool at the PRV inlet line to provide a positive isolation you need flanged connections for such pipe spool...
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
Relief Path To Be Considered For Inlet Pressure Drop CalculationStarted by Guest_Ascanio E._* , 09 Jul 2025 |
Tank Inlet Diffuser LengthStarted by Guest_RAFAELDAVE_0752_* , 08 Apr 2025 |
