Falling Film Evaporator - How Many Stages
#1 Orzelgorskiego
Orzelgorskiego
  • 28 posts
Posted 15 November 2020 - 05:44 PM
HI,
I was wondering how to estimate how many stages of the falling film evaporator I need?
Where should I look to find the answer for which data or value?
I am using in the process waste steam.
Thank you for help.
Tomasz
Cannot connect to Ginger Check your internet connection
or reload the browserDisable in this text fieldEditEdit in GingerEdit in Ginger×
Enable GingerCannot connect to Ginger Check your internet connection
  • 6,940 posts
Posted 15 November 2020 - 08:42 PM
A few documents and link to support your work :
https://nzifst.org.n...evaporation.htm
Figures are available in the link above ( steam consumption / water evaporated ) vs number of effects .
To me MVR should be investigated for this type of process .
Hope this is helping you.
#3 Orzelgorskiego
Orzelgorskiego
  • 28 posts
Posted 16 November 2020 - 03:54 PM
Enable GingerHi Breizh,
Thank you very much for help. These materials will be usefull.
Best regards,
Tomasz
#4 Orzelgorskiego
Orzelgorskiego
  • 28 posts
Posted 03 January 2022 - 03:37 AM
Enable GingerHi Administartor,
Could you explain more precisely how to determine the number of stages for multiple installation of evaporators. Maybe we can use an example.
I have stcickwater flow of 4800kg/hr and I would like to evaporate 3200kg/hr .
I have residueal vapour of 1800kg/hr which will go to the evaporator.
How many stages should I use? I, II or III?
Thank you
or reload the browserDisable in this text fieldRephraseRephrase current sentenceEdit in Ginger×
