Different Set Pressure In Heat Curve Of Htri
#1 nastaran
nastaran
  • 32 posts
Posted 18 November 2020 - 12:12 AM
Dears,
I'm supposed to define the heat curve of a condensing fluid in HTRI with different pressure.the properties is as the following:
https://pasteboard.co/JASKPbt.jpg
As you can see the vapor fraction is one for the first three points, so there is no liquid properties in these points.But the HTRI is undefined for liquid properties for the points without liquid and I don't know how to define these properties.Please guide me for this purpose.This is my HTRI image:
https://pasteboard.co/JASNRdj.jpg
Thank you in advance.
Edited by nastaran, 18 November 2020 - 12:15 AM.
#2 IGC
IGC
  • 54 posts
Posted 18 November 2020 - 03:35 AM
You need to ask for more information from the client, at least two different pressure profiles for the condensing section, or generate new properties yourself.
#3 nastaran
nastaran
  • 32 posts
Posted 18 November 2020 - 05:28 AM
Thank you for your reply.
I think that the properties is complete in thermodynamic point of view.When temp is in range of 90.9 to 83.7 all components are vapor,therefor we don't need the liquid properties.So I should be logically  able to define a set for pressure of 1.4  bar without liquid properties. :unsure: :unsure:
#4 Pilesar
  • 1,576 posts
Posted 18 November 2020 - 07:08 AM
Since you defined the fluid as condensing, HTRI expects the fluid to be condensing and needs liquid properties. Extend the curve to include condensed liquid. Use the liquid properties at the dew point to fill in missing data.
Edited by Pilesar, 18 November 2020 - 07:09 AM.
#5 IGC
IGC
  • 54 posts
Posted 18 November 2020 - 09:32 AM
You need;
At least two pressure profiles (so 1.4 and 1.3 barg in your case), containing:
Minimum one superheat point
Minimum one subcooled point
Multiple points spanning the two-phase region.
This is direct from HTRI's training.
Edited by IGC, 18 November 2020 - 09:32 AM.
