Atm Storage Tank In-Out Breathing Calculation Excel Worksheet Fps Unit
tank calculations tank inbreathing
#1 RUBABU
RUBABU
  • 30 posts
Posted 23 November 2020 - 05:42 AM
Atmospheric Storage Tank In-Out breathing calculation excel worksheet by Ankur Srivatsava in SI units is available as attached.
If the same is available in FPS units, kindly share please.
  • 1,637 posts
Posted 24 November 2020 - 09:57 AM
I recommend building your own calculation sheet. See this article for the equations: http://webwormcpt.bl...g-proposed.html
The equations in the article are the source for the spreadsheet. It is not in the units you want, but Excel has a CONVERT worksheet function CONVERT(number,from_unit,to_unit) which takes some of the burden off of unit conversion calculations. Convert your input units to the calculation units then convert the results to your desired output units. This process is made easier since you can check your results with Ankur's spreadsheet to make sure you did not make an unintentional calc mistake. Putting together your own spreadsheet takes some time, but you learn by the doing. With experience, it then becomes an easy matter to add converted units for other spreadsheet calcs.
#3 RUBABU
RUBABU
  • 30 posts
Posted 30 November 2020 - 12:11 AM
Thank you very much.
#4 breizh
  • 6,940 posts
Posted 30 November 2020 - 12:49 AM
You should consider to buy UCONEER from our member Katmar, the best converter in the class! .It will help you to resolve this type of problem.
https://www.katmarsoftware.com/
To add to Pilesar's answer  a PPT presentation .
Edited by breizh, 30 November 2020 - 12:52 AM.
