1. wet crude storage tank of known capacity, oil API, inlet oil in water content etc.
2. designed for gravity separation of oil from water with feed from oil/gas separators bottom water stream
3. tank outlet water flow designed for of 1000 ppm oil in water spec
to identify the impact of higher water inlet flow rate on outlet oil in water spec, request your guidance please like on sample sizing worksheet etc. to estimate oil in water outlet spec. due to increased inlet water flow rate
