Hello everybody.
I study Chemical Engineering and I'm in my final year. We are currently working on a team project which includes designing a combined heat and power unit by using a hydrogen fuel cell and a burner to supply a local hotel with heat and power.
However, one particular device that has been troubling us is the burner/furnace. We can't seem to find any specific information about the sizing of burners, except for a few papers on how they work. I should also note that we won't be probably using a fired heater because we're having some issues with our simulation program (unisim).
So, could somebody please give me the design equations for burner/furnace sizing? If there aren't any, should I use the regular design equations for a CSTR reactor? Any suggestions will be really appreciated. Thank you very much in advance.
Burner/furnace Sizing
Started by Thanasis, Dec 04 2020 02:34 PM
Posted 04 December 2020 - 02:34 PM
Posted 04 December 2020 - 04:53 PM
So, what is the scope for your project? Burner design is typically done by the manufacturer. And the furnace you mention is a steam generator, a special furnace, called a boiler. Again, such is designed by a manufacturer.
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Separator SizingStarted by Guest_HOTTEST_* , 12 Mar 2026 |
Psv Downstream Line SizingStarted by Guest_Abdessamed1961_* , 03 Mar 2026 |
