Ia Failure Relief Scenario
#1 274@P6
274@P6
  • 43 posts
Posted 09 December 2020 - 05:45 AM
Hi to all,
1. How to calculate the relief load for the Instrument air failure case?
2.How this Instrument air failure scenario will differ from blocked outlet case?
#2 fallah
  • 5,026 posts
Posted 09 December 2020 - 07:04 AM
1-The loss of IA will normally lead to total shutdown; hence due to the limited flare capacity simultaneous depressurization of the total units isn't possible then a sequential depressurizing is inevitable. You can estimate the relief load of each sequence depressurization and select the highest value as the relief load of IA failure.
2-IA failure is a common failure leading to several relief toward the flare while BO is a local failure with normally a single relief to the flare.
#3 Technical Bard
Technical Bard
  • 407 posts
Posted 09 December 2020 - 03:41 PM
For instrument air failure, you need to consider what position every air-driven control valve actuator will move to.  Valves that are spring-to-close or spring-to-open will move to their "failure position".  Then you look at how accumulation of material or heat in the process could cause overpressure.
#4 274@P6
274@P6
  • 43 posts
Posted 10 December 2020 - 04:44 AM
thank for the clarification @fallah and @Bard.
1. During the blocked outlet scenario in group header (Two phase), the outlet line of PSV connected to either flare header or closed drain?
2. For Indirect bath heater and Heat exchanger TSV is connected to closed drain but sometimes its connected to flare header. which one is correct?
Edited by 274@P6, 10 December 2020 - 04:46 AM.
