Chem Cad Simulation
#1 Lila54
Lila54
  • 5 posts
Posted 20 December 2020 - 01:52 PM
I was given this project I have to complete the process flowsheet but i am unable to determine the process if any one can help me i would be thankful that.  i have attached the the question.
The following block diagram represents a process in oil and gas industry. The process starts with removing H2S and CO2 gases from the inlet gas stream. The process goal is to produce methane and propane gases as per the mole fraction mentioned on the block diagram. Also, the specifications of some unit operations are given on the diagram. Your task as a process engineer is to simulate the process that meets the provided feed and product streams properties and to address the following tasks.
  • 6,942 posts
Posted 20 December 2020 - 06:31 PM
Hi Lila ,
Consider the resources attached to support your work  , you should find hints :
https://www.chemstat...ith_CHEMCAD.pdf
Edited by breizh, 20 December 2020 - 06:32 PM.
