Hello everyone. I'm doing a research on synthesizing a conducting plastic from carbon black and ptfe where I wish to obtain a very thin layer of ptfe over carbon black in order to get a conducting plastic which is also non-permeable to water. I'm a little stuck at finding the most optimum mixing technology for the same. I have considered the bottom-up-approach in nanotechnology and used the sol-gel process but didn't got any success. Now I'm considering using electrospinning but PTFE is not soluble in most of the solvents. So how can I use electrospinning here or is there any other suitable technique which I should use?
Synthesizing A Conducting Plastic
Started by _aryaman, Dec 30 2020 04:16 AM
nanotechnology electrospinning polymers carbon mixing conducting plastic. bottom up approach
No replies to this topic
Posted 30 December 2020 - 04:16 AM
Synthesizing Zeolite Y From Cowlin Clay Through DealluminationStarted by Guest_emmanuelv2012_* , 18 Dec 2016 |
Synthesizing Zeolite Y From Cowlin Clay Through DealluminationStarted by Guest_emmanuelv2012_* , 17 Dec 2016 |
Guidance For Plastic Related Chemicals CourseStarted by Guest_inelastic_* , 23 Aug 2014 |
Asme B31.3 Requirements For Hydrostatic Testing Og Hdpe Plastic PipinStarted by Guest_cbossen_* , 23 Jun 2014 |
Why Avoid Plastic?Started by Guest_didmac0_* , 19 Aug 2010 |
