Multiple Property Method In Same Aspen Plus File
aspen plus property package
#1 ChinmoyBasak
ChinmoyBasak
  • 61 posts
Posted 02 January 2021 - 10:00 AM
I know we can override the default global options in each unit operation in aspen plus, to have different property in a specific unit operation.
But I have to use regression in two of the property package. So as far as I know we can do regression in only principal property package. But I need in total three property package and and two regressed property package in same simulation.
Example My needed property packages are
UNIFAC (Contains Polar substance) in around Reactor
CPA (Need VLE regression for separation) In separation Section 1
ENRTL (Contain Ions and need VLE & LLE regression for separation) In separation Section 2
My separate simulations are ready but I don't know how to have them in the same simulation file.
Will, really appreciate your suggestions.
Edited by ChinmoyBasak, 03 January 2021 - 06:06 PM.
#2 Bobby Strain
Posted 03 January 2021 - 11:29 AM
You should consult AspenTech support. HYSYS supports different property packages in subflowsheets. Aspen plus may, too.
Edited by Bobby Strain, 03 January 2021 - 01:01 PM.
#3 Pilesar
  • 1,637 posts
Posted 03 January 2021 - 01:20 PM
Have you tried regressing the properties you need and then saving the regression coefficients? It is not usual to perform a new thermo property regression every time you run the simulation. You should only need to regress the properties once. After that, include the result in the property method.
#4 ChinmoyBasak
ChinmoyBasak
  • 61 posts
Posted 04 January 2021 - 08:25 AM
Thank you sir. I will try to find ways to save the regression coefficients. I am currently not aware of the procedure. Appreciate your response.
