Asme Code For Low Temperatur Lpg Pipeline
#1 Butterfly
Butterfly
  • 87 posts
Posted 21 January 2021 - 04:48 PM
Hello
I have a liquid LPG pipeline, several km long. Design temperature is well below -30ºC.  I wanted to use B31.4 code, but it is limited to minimum design temperatures above -29ºC. Shall I use B31.3? Which one is correct?
Thank you
  • 6,942 posts
Posted 21 January 2021 - 09:25 PM
Considerer the links below , you should find your answer :
https://www.engineer...iping-d_39.html
https://law.resource...i.2510.2001.pdf
B31-3 seems to be the right one.
Edited by breizh, 21 January 2021 - 09:28 PM.
#3 Butterfly
Butterfly
  • 87 posts
Posted 22 January 2021 - 05:49 AM
Thank you
