1,3 Butadiene Extraction Simulation
8 replies to this topic
#1 tranthenam
tranthenam
  • 3 posts
Posted 25 January 2021 - 10:43 AM
Hello everybody. I'am trying to simulate my 1,3 butadiene plant by extractive distillation using NMP solvent by hysys software. Does anyone has experiences about it. Please help me. I tried to used several fluid packages, but the result didn't correct.
#2 tranthenam
tranthenam
  • 3 posts
Posted 30 January 2021 - 04:12 AM
please help me..
#3 latexman
  • 1,900 posts
Posted 30 January 2021 - 09:47 AM
You have not shown your model, or described it and the thermo. methods you are using.  So, we have nothing to look at.  You said it is not correct, but we don't know what is not correct.  Who do you think we are, the Amazing Kreskin?  Only you, can help us help you.
#4 StealthProg
StealthProg
  • 74 posts
Posted 30 January 2021 - 06:03 PM
Use A+ NRTL, you will likely have to regress some data to get good parameters for the NRTL
#5 breizh
  • 6,973 posts
Posted 30 January 2021 - 08:51 PM
latexman is right ! we are not wizard.
Did you try your favorite search engine ?
https://link.springe...1814-012-0075-3
https://www.research...olidone_solvent
Edited by breizh, 30 January 2021 - 08:59 PM.
#6 SilverShaded
SilverShaded
  • 237 posts
Posted 31 January 2021 - 12:30 PM
If you don't have any real data then you may be able to estimate the NRTL parameters using UNIFAC.
#7 tranthenam
tranthenam
  • 3 posts
Posted 31 January 2021 - 08:30 PM
dear sir.
I'am sorry, I can not show the simulation because it's confidential document. I tried to used NRTL-RK method for fluid package and UNIFAC to predict the binary paramter of component. But when I reduce pressure through a valve, the flowrate of vapor and liquid not correct that lead the result not correct.
#8 Pilesar
  • 1,652 posts
Posted 01 February 2021 - 12:30 AM
A couple of suggestions:
1) tune your thermodynamic package against published data such as from here: https://www.scienced...378381289800408
2) Contact BASF for modelling guidelines since they developed this technology.
#9 pmoneysh
pmoneysh
  • 31 posts
Posted 09 February 2021 - 06:29 PM
Your question is vague. For extractive distillation, next to the choice of right thermodynamic model, important aspects include the amount the solvent  and the reflux ratio. Further, how did you calculate the required number of trays or packing height and what is the purity and recovery of the components? Binary interaction parameters available for all the pairs?
