Edited by ChinmoyBasak, 15 February 2021 - 04:15 PM.
Posted 15 February 2021 - 06:35 AM
Posted 17 February 2021 - 05:37 AM
From literature , EO is very much soluble in water ( High Henry coefficient) .
https://www3.epa.gov...01_ch3_1997.pdf
Using Chemsep light , attached the results .
Flowrate unit is wrong, should be kmol/h
Hope this is helping you .
Edited by breizh, 17 February 2021 - 08:00 AM.
Posted 17 February 2021 - 11:04 AM
Thank you so much for taking the time to do the separation on behalf of me.
May I know which property package are you using in ChemSep? I have failed to do it in Aspen Plus and ChemCad.
Thank you.
Posted 17 February 2021 - 05:13 PM
a) Raoult's laws .
Good luck,
Edited by breizh, 18 February 2021 - 02:14 AM.
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
Ethylene Oxide Off-SpecStarted by Guest_Movers_* , 25 Feb 2026 |
Acidic Condensate In Sulphate Recovery By Vapour SeparationStarted by Guest_Ranga v_* , 09 Nov 2025 |
