Economical Tradeoff Of Gas Compression Pressure Vs Tank Size?
7 replies to this topic
#1 RonC74
RonC74
  • 5 posts
Posted 02 March 2021 - 04:08 PM
I need to compress and store CO2, I am trying to figure out what will be the most economical pressure to store the CO2. More compression means a more expensive compressor but a smaller storage tank, vs a larger tank with less compression.
Or maybe it will be more economical to liquefy the CO2? Does anyone have any suggestions?
#2 Bobby Strain
Posted 02 March 2021 - 04:12 PM
How much do you need to store?
#3 RonC74
RonC74
  • 5 posts
Posted 02 March 2021 - 04:18 PM
around 3200 kg of CO2.
#4 breizh
  • 6,939 posts
Posted 03 March 2021 - 01:46 AM
more info are needed !
what is the quantity per day or per hour ? how many days a year ?
The more you describe your operation the more you will get a proper answer .
#5 RonC74
RonC74
  • 5 posts
Posted 03 March 2021 - 08:28 AM
The propose of this system is to recover the CO2 from a batch reactor every 6-7 hours. The reactor is filled with CO2 at 120 PSI, industrial grade CO2, I will need to empty the reactor within 30-60 min, compress or liquify the CO2, and store it for the next batch.
Ron
#6 MrShorty
MrShorty
  • 519 posts
Posted 03 March 2021 - 01:40 PM
It seems to me that storage temperature is an important consideration here. CO2's critical temperature is about 30 C. If the storage temperature can be higher than that (say in an outdoor environment where there would be no temperature control), then there is no point in considering deliberately liquifying the CO2, as it will not stay liquified if it can rise above 30 C. On the other hand, if it is in a temperature controlled environment so that it can never rise above something like 20 C, then there could be very real value to compressing it above the saturation pressure so that it will condense into a liquid.
#7 breizh
  • 6,939 posts
Posted 03 March 2021 - 08:02 PM
You may find pointers in this tutorial .
https://oaktrust.lib...e=1&isAllowed=y
#8 breizh
  • 6,939 posts
Posted 04 March 2021 - 07:31 AM
another document to support your work,
Hope this is helping you .
Edited by breizh, 04 March 2021 - 07:37 AM.
