Temperature Difference Heat Exchanger
heat exchanger lmtd temperature difference
#1 Petridou
Petridou
Posted 04 March 2021 - 04:22 AM
Hello
I am an undergratuated student and I am designing a heat exchanger. I couldn't be able to find how large can the temperature difference be. For example, can I use only one heat exchanger to heat directly a fluid from 293 Kelvin to 873 Kelvin, or something like that is impossible and so I should use more than one heat exchangers? What is the typical maximum temperature difference that can be achieved ?
Thank you in advance
  • 6,942 posts
Posted 04 March 2021 - 05:03 AM
https://www.cheresou...ure-difference/
let you consider the link above .
BTW you can also explore the subject using your favorite search engine or the one in this forum.
note : Did you ask the question to your instructor ?
remark : Process heat transfer  by Kern is a good reference.
Hope this is helping you .
Edited by breizh, 04 March 2021 - 06:33 AM.
#3 Petridou
Petridou
Posted 05 March 2021 - 04:57 AM
Thank you very much, I found a lot of useful information in the attached files
#4 mhamdi khaled
mhamdi khaled
  • 50 posts
Posted 22 October 2021 - 04:00 PM
You have to know that this difference of temperature should have many exchangers. Try to use EDR, it gives the full design and also the required number of exchangers
#5 Nikolay_
Nikolay_
  • 169 posts
Posted 27 October 2021 - 08:02 PM
It's hard to imaging. To heat something to 873 K you need a heater.
#6 Nikolay_
Nikolay_
  • 169 posts
Posted 27 October 2021 - 10:39 PM
You can see below method of identifying if lens compensator needed.
