Fired Heater Fuel Gas Cascade With Temperature
Posted 07 March 2021 - 10:40 AM
In our process plant we have Fuel Gas FTs which gives us reading in Nm3/hr and we want to calculate from this reading actual fuel gas flow taking into account temperature, pressure and specific gravity corrections.
Which is the most accurate formula for calculating flow rate? What are the best practices followed by other refineries in order to calculate the fuel gas flow, do they apply temperature and pressure correlations? Pressure or density which is better to take in .
Some time the actual fuel gas link with LHV to more accurate.
Posted 07 March 2021 - 11:37 PM
Normal m3 , pay attention to the definition of Normal ( P ,T) .
You can calculate the density at (P,T) using perfect gas law or EOS and then you can get access to the mass flow rate ( volumetric flow rate * density).
Posted 07 March 2021 - 11:43 PM
How do you calculate actual flow rate of Fuel Gas from the flow meter reading?
Post Title isn't compatible with what is requested in the post content...
Centrifugal Compressor Cmpression Ratio /discharge Temperature LimitStarted by Guest_Lyne_* , 16 Mar 2026 |
Handheld Ethanol Fuel Content AnalyzerStarted by Guest_Sciosophy_* , 03 Mar 2026 |
Relieving TemperatureStarted by Guest_Falah_* , 01 Feb 2026 |
Low-Temperature SeparatorStarted by Guest_guoyinyanliner_* , 15 Aug 2025 |
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
