At Our plant has three screw type propane refrigeration compressor.
since the past 6 months, we have been using a compressor with low calculated differential oil pressure which is causing tripping to compressor due to low frick oil differential pressure.
When we did the oil test found ok, we also changed the frick oil cartidge filter, but so far the problem has been that of low-calculated oil differential pressure.
which is causing tripping of propane refregeration compressor.
Please guide us.
Propane Refregeration Compressor
Started by Muhammad Hamid Khan, Mar 27 2021 11:18 PM
No replies to this topic
Posted 27 March 2021 - 11:18 PM
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
Centrifugal Compressor TroubleshootingStarted by Guest_sggifrance@gmail.com_* , 14 Sep 2025 |
