Multistage Pump
10 replies to this topic
#1 Jaldhipatel
Jaldhipatel
  • 56 posts
Posted 04 April 2021 - 12:37 AM
It is possible that i have 2 fluid one is lighter in density and other is heavier..then for same discharge head i need multistage pump for lighter one and single stage pump for heavier fluid.
#2 fallah
  • 5,026 posts
Posted 04 April 2021 - 02:57 AM
In general, you need to design the pump for heavier fluid...
#3 Jaldhipatel
Jaldhipatel
  • 56 posts
Posted 04 April 2021 - 07:22 AM
Sir i have to transfer fluid to same height but 1) lighter 2) heavier fluid then it is possible that for lighter fluid i require multistage pump but for heavier i need single stage pump...is this possible..
#4 Bobby Strain
Posted 04 April 2021 - 09:23 AM
You must perform hydraulic calculations to ascertain. That's what engineering is about.
#5 bibalan
bibalan
Posted 06 April 2021 - 12:27 AM
If you are talking about centrifugal pumps and suction pressure and viscosity of fluids are similar, you would need a single stage pump for lighter fluid and extra stages to reach the same height for heavier fluid. Pay attention to pump curves for different viscosities.
#6 Jaldhipatel
Jaldhipatel
  • 56 posts
Posted 06 April 2021 - 10:32 AM
Is that any specification for which we have to use multistage pumps..? Pls guide as i want more knowledge about where to use multistage or single stage...pls help..
#7 justinallen
justinallen
Posted 13 April 2021 - 02:24 AM
When you attempt to mix two liquids which have different densitiesthey separate when you stop mixing them. The "heavier" liquid deposits itself on the bottom and the "lighter" liquid deposits itself on top. There exists a wide range of liquids with various densities.
#8 Chemitofreak
Chemitofreak
  • 292 posts
Posted 13 April 2021 - 05:52 AM
If I were you, I would have done hydraulic calculations for both the cases i.e. high and low density. I will put both the cases on the datasheet and let the vendor decide.
If you want a quick check if single stage or multistage pump is required, ask your Mechanical Dept. or google for pump selection chart some thing like the below:
https://www.research...fig21_286198429
#9 POuria95
POuria95
Posted 20 April 2021 - 01:01 AM
There is one rule of thumb for choosing multi stage or single
for each 150 m head you need one stage.
and its not depended on density and viscosity.
#10 breizh
  • 7,030 posts
Posted 20 April 2021 - 02:52 AM
https://blog.craneen...l-pump-used-for
hi,
Let you try your favorite search engine and talk to representatives in your area.
#11 horatorres
horatorres
  • 88 posts
Posted 20 April 2021 - 07:15 PM
you should calculate the pump head requirements for both cases,, light and heavy fluid.. It will give you your power, head and discharge pressure,
Multistage pumps are used when a normal one stage pump will no handle the head requirements, Usually each stage have 60 mt head as upper limit, (6 bar as discharge pressure) but the manufacturer must give you this advice,
Horacio
Edited by horatorres, 21 April 2021 - 11:33 AM.
