Hydraulic Liquid Surge Calculations
#1 Chemitofreak
Chemitofreak
  • 292 posts
Posted 12 April 2021 - 03:31 AM
Is hydraulic liquid surge calculations carried out for on-plot (inside a unit) systems (pumps, valves)? I have seen these calculations generally carried out for off-plot long run piping or cross country pipelines.
If yes, then what is the criteria for these calculation for on-plot systems, because I have never seen these calculations for on-plot system (having said that, I may be wrong)
Thanking you in advance.
Take care and stay safe.
#2 Chemitofreak
Chemitofreak
  • 292 posts
Posted 14 April 2021 - 07:29 AM
#knock knock....can anyone help me on this query
#3 Pilesar
  • 1,635 posts
Posted 14 April 2021 - 07:59 AM
Search the internet for 'water hammer calculation' to see what is available. For short lengths, detailed calcs are not usual. Good engineering practice during design avoids most problems. Avoid slug flow when possible and support the piping. Avoid long straight lengths of two-phase flow. In plant, the cost adder is not great. For discovered plant problems, the solution again does not require too detailed calcs when the obvious change for example is just a slower valve closing or addition of a pulsation dampener.
