What temperature measurement device would be used to measure water temperature in a tank at atmospheric pressure? Would a thermocouple work? If so, could that one be grounded or would the water cause electrical interference with the water? If that doesn't work, does a thermowell have to be used?
Posted 23 April 2021 - 09:55 AM
Posted 23 April 2021 - 10:23 AM
I've used thermocouples (ungrounded sheath) in similar applications. Most if not all suppliers can offer both sheathed and unsheathed versions, where you would choose an ungrounded sheathed version when you need electrical isolation. https://www.instrume...industrial.html
Posted 24 April 2021 - 01:43 PM
Good Day
We use thermowell for all applications. The head has an assembly that no let water going into the electrical wire
Horacio
