While using C60 steel shaft for an application, it was first coated with anti-corrosion agent containing mineral oil. After that, a little bit of PTFE based grease was applied to the splines of the shaft. But due to this, the shaft started rusting.
Basically, I want to know what will be the reaction of:
Mineral oil (C16H10N2Na2O7S2) + TFE (C2F4)+ Fe -> ?
Does the grease react with the anti-corrosion agent and dissolve it? Or is there no affect at all?
