Error Plotting Ternary Diagram With Aspen Properties
aspen properties mixtures simulation error distillation ole
#1 VLCENG
VLCENG
  • 8 posts
Posted 15 May 2021 - 10:29 AM
I am trying to generate a ternary diagram of a water/ethanol/ethylene glycol mixture, but it gives me an error for upper bound violation for EG. I have attached the ternary map inputs as well as the error, if someone could please have a look and tell me where they think the problem is.
Attached File  Screen Shot 2021-05-15 at 14.22.14.png   390.42KB   0 downloads
Attached File  Screen Shot 2021-05-15 at 14.08.34.png   153.6KB   0 downloads
Thanks for your time
#2 latexman
  • 1,866 posts
Posted 15 May 2021 - 12:46 PM
Water/ethanol/ethylene glycol is not a candidate for VLLE.  They are all 100% soluble in each other.  Go for VLE.
#3 VLCENG
VLCENG
  • 8 posts
Posted 15 May 2021 - 04:00 PM
In that case it asks for a temperature input, according to what would I select that?
#4 latexman
  • 1,866 posts
Posted 15 May 2021 - 04:50 PM   Best Answer
At 1 atm pressure, somewhere between the normal boiling point of ethanol (78.2 C) and ethylene glycol (197.3 C), would be my guess. Where do you want/need the properties to be at?
