Aromatics Extraction Using Sulfolane Solvent
aromatics sulfonale liq-liq extraction
#1 Geetanjali
Geetanjali
  • 40 posts
Posted 18 May 2021 - 03:44 PM
Hello everyone,
I hope you are doing well. I need suggestions and pointers for the project that I am doing for the extraction of aromatics from a mixed HC feed. I plan to use the sulfolane process designed by UoP. I understand that I have to use 1. an Extractive distillation column to separate aromatics from non-aromatics using sulfolane solvent 2. Wash column to separate heavy aliphatic from the aromatics and solvent rich stream, and finally 3. A solvent recovery system, that would separate sulfolane solvent from the aromatics stream. It is at this stage (no 3) that I am facing problems).
I read a lot in the literature about possible ways to do this separation. Options include vacuum and steam distillation. I tried to do a steam distillation by selecting Extract column (from Aspen Plus) and put steam to do the separation. But it is not helping. Could anyone please suggest some help in this direction?
I would be grateful for the help.
Thanks,
Geetanjali
  • 1,635 posts
Posted 18 May 2021 - 05:11 PM
I find a lot of details about the separation column conditions here: https://commons.und....&context=theses
Is this document included in your literature search?
#3 Geetanjali
Geetanjali
  • 40 posts
Posted 21 May 2021 - 12:55 PM
Thank you Pilesar. This document is helpful and I am working on my simulation referring to it. I appreciate your assistance.
#4 Geetanjali
Geetanjali
  • 40 posts
Posted 25 May 2021 - 02:56 PM
Hello again,
Just wanted to give an update. I was able to find a workaround for my problem and my problem is solved. Thanks for your help. Appreciate it.
Best regards,
Geetanjali
