Spiting Recycle Stream Does It Need A Compressor In Returning Stream?
#1 lnbsak
lnbsak
  • 53 posts
Posted 03 June 2021 - 03:07 PM
Please go through the attached flowsheet below.
https://ibb.co/tJhD0Mv
My question is 408 stream should have some compressor for it to mix with 412 stream
Am I wrong?
  • 1,563 posts
Posted 03 June 2021 - 03:44 PM
From the information supplied in the diagram, no compressor is necessary to mix streams 412 and 408. The mix of 412 and 408 (stream 409) will have its pressure at the lower of the two streams.
Edited by Pilesar, 03 June 2021 - 03:45 PM.
#3 Bobby Strain
Posted 03 June 2021 - 10:42 PM
You never need to use a compressor if there is some quirk in your simulation. You can use a valve with a negative pressure loss.
#4 lnbsak
lnbsak
  • 53 posts
Posted 05 June 2021 - 07:06 PM
Thank you for reassuring.
